4020 White smoke and a knock?
Fudpucker
09-19-2006 22:01:17
Here I go again. Someone once told me that the most expensive way to buy a tractor is one piece at a time and that is what I seem to be doing. The situation now is the tractor takes forever to start in the mornings. Prior to starting I can prime the fuel pump and about five strokes.. Is that normal for it to lose it"s prime. I am assuming that this is why it is taking so long to start. When it does start it smokes white all day unless it is under heavy strain then it is black. The coolant level stays normal. When I throttle it up from low idle I ahve begun to hear a low knocking, not sure from where. It goes away when under normal use. Yesterday I was standing by it while it was idling and I heard the knock again. It will knock and then quit the sound is similar to when you use ether to start an engine. Someone told me it might be an injector going bad. I don"t know about that though. The oil pressure is good at all engine temperatures and the injector pump is new. Any thoughts including getting another tractor would be appreciated. Thanks.
Fud
Gerald J.
09-20-2006 08:47:19
 Re: 4020 White smoke and a knock? in reply to Fudpucker, 09-19-2006 22:01:17
The lift pump on my '68 gas 4020 wore out so the tractor only ran with more than a third of a tank of gas. I don't know why the lift pump in yours shouldn't be as worn. A bad lift pump can also contribute fuel to the crankcase compensating for oil burned from worn rod bearings and piston rings.
White smoke on a diesel I hear can come from unburned fuel or from water. Unburned fuel comes from poor atomization from injectors or low compression. With low compression, it wouldn't start without ether.
Gerald J.
msb
09-20-2006 08:23:18
Losing prime is caused from the check valve in the small fuel transfer pump as a rule. The white smoke could be from several causes including improper timing.It should be set at TDC.The first thing I would do after checking the timing and the return line is pull the injector nozzles and have them checked by someone who really knows how they should function.Are your nozzles the pencil type or the older large nozzles.Either one can cause a knock ,but the older nozzles were a lot worse about creating a knock.
The knock could be from the hyraulic pump coupler as someone suggested below.If you don't have an engine stethescope(sp?)then use a long screwdriver and listen with your ear on the handle to help determine where the knock is coming from.But pull all the injector nozzles if you think the noise is coming from only one.I don't know how many times I was wrong when listening and pulled the wrong one. The knocking sound really carries to other nozzles in this case. Was the fuel return line going back to the fuel tank blown out real good when the injection pump we replaced? A partially plugged line can cause some of your problems that you list.
billyiron
09-20-2006 07:14:25
I have almost the same thing in my 66 4020,but mine starts well but has a miss and white smoke untill pulled hard ,no knock,I just got the tractor and it had been setting for a long time,at night when you crack the throttle it will blow flames out the exhaust about 10-12 inches, lots of power,I was going to try some fuel conditioner and put it on the grainvac, and pull the crap out of it and hop it straightens out,,let me know if yours gets better and what you did,,billy
Mike M
09-20-2006 06:13:34
Fuel check valve is built in the transfer pump. Could be the pump timing is off makeing that white smoke.
WyoDave
09-20-2006 05:15:32
White smoke even when warm would concern me. Mine smokes a bit at start up, but goes away pretty quick like. I had a knock as well, but it was only the hydraulic pump coupler. Have you replaced the bushings in that? It shouldn't need primed every time either, somewhere it must be bleeding back.
David
J Schwiebert
09-20-2006 05:01:12
White smoke at starting and then having white smoke till it gets under load is a sign that compression is on the low side causing hard starting. No doubt if you run it for a while under load enough heat is generated to make it start easier. Questions?
Tx Jim
09-20-2006 03:36:48
No you shouldn't have to pump up fuel before cranking. I can't remember if 4020's had a fuel check valve to prevent bled-back but one could be installed. First check and see if you have a pin-hole in fuel line from tank. While checking line check your hyd. pump coupler for worn bushins or splines as this can cause a knocking sound that goes away when hyd's are used.
fudpucker
09-20-2006 18:59:56
 Re: 4020 White smoke and a knock? in reply to Tx Jim, 09-20-2006 03:36:48
Thanks for all of the responses. I beleive I'll let someone who knows more than me take a look at it. What could be causing the low compression. The engine has 300 hours on a rebuild. Thanks again.
Fud
