730 Coolant heater
coastiejim
09-19-2006 16:55:13
Does anyone know if John Deere or anyone else ever sold a 120V Coolant heater that threaded into the head either in the bottom drain or one of the 2 plugs on the front of the head. Any help is appreciated.
Thanks Jim
Duane(Pa)
09-20-2006 08:36:16
 Re: 730 Coolant heater in reply to coastiejim, 09-19-2006 16:55:13
Yes, you can get a modern, aftermarket, engine heater that will screw in where the drain plug was. it may not have the wattage that the OEM heater has, but it will be adequate.(and alot cheaper) I think it's 3/4" pipe thread but not sure. I would give NAPA a try, or Google.
mjbrown
09-19-2006 18:17:20
Mine has one. Not Deere though, it looks rather modern and it is where you described. It works well.
james2
09-19-2006 17:43:49
Yes they did and probably still do. I bought one about 10 years ago. Paid $125 but it is a gem. A lot of brass. It was in the old original box. The dealer probably had it for 30+ years. I've got an old parts book reproduction which shows the cost to the customer was $7.50. The dealer probably bought mine for $2-3. Not a bad return even though it took 30 or so years to get it.
