1950 B that won't start
Dean Lydey
09-19-2006 13:08:00
I've got a B that's been lately causing me trouble. I let rain get in the intake earlier in the summer and really caused some grief. When I emptied the water/oil from the oil bath filter, it ran much better.
Last weekend the little rascal wouldn't start. I've opened the petcocks and it's getting fuel. I looked at the plugs and their providing spark. I'm not sure what to look for with spark but it was yellow. The mag was rebuilt last summer. The plug wires seem serviceable but they are old. I find myself concentrating on the plugs because they're easy to change and in the past changing the plugs when it was hard to start has fixed the problem. The wrench flat of the Champion plug has been best to get the plug in and out. I believe I'm using D-16's.
#1 Is this the plug you'd recommend? If it matters the tractor is gas.
#2 Any other suggestions to get it started? Could my goof up with water in the intake be giving me carb grief. Is a carb rebuild the answer?
I've been told that assuming the timing hasn't been tinkered with, and it hasn't, it's basically about spark and fuel to make these run.
Thanks,
Dean
johns48b
09-20-2006 09:43:33
 Re: 1950 B that won't start in reply to Dean Lydey, 09-19-2006 13:08:00
when i was restoring my be and i had the air intake mounting bracket off to clean it up there was a hole in the bottom of a cup built into the bracket that i think was put there to let rain water out if any got in. if its plugged up you may have to dig some to find it but it will keep the rain water out of your oil bath cleaner.
John T
09-19-2006 17:34:10
Dean, My best guess is its a mag problem, the FIRST thing I would do is run a dollar bill or shop cloth ect between the points to non abrasively clean/buff/polish any gray oxide coating off them and check their gap. In the event they were burned or pitted or carboned up badly REPLACE THEM. Next I would try a fresh set of Autolite 3116 NON resistor plugs (D 16 are much too cold for my liking),,,,, ,,and a new set of wire core NOT carbon core suppressor plug wires. Then adjust the carb and insure theres fresh clean water free gas getting to n through the carb n see what happens. Once you get a good BLUE spark n frech clean gas with those new hotter plugs let us know the verdict.
John T
Dean Lydey
09-19-2006 17:04:40
Thanks for the input. Plugs and wires, huh. I thought that yellow spark wasn't a good sign. This sounds like an inexpensive and straight forward solution.
Thanks Again!
Dean
buckeye al
09-19-2006 14:06:00
The spark should be nice and blue. If not I'd check into the mag. This is especially true if as you say it sat out & got wet. Likely it's wet inside & just not real happy.
As for the Champion D16 plugs. Even Champion says not to use this plug for anything but very heavy service! That is simply begging for troubles!
For average service Champion recommends the D21 and for light service or where fouling is a problem, the D23. I have great luck with both.
Most guys don't like Champion plugs and will recommend an Autolite 4688 or something like that. I believe it depends as much on what brand your local suppliers carry as much as anything.
Check out the mag & get some new AND DIFFERENT plugs!
Paul from MN
09-19-2006 14:02:13
Sounds like a weak spark to me. The spark should be bright blue. Could be a weak mag, plug wires or plugs. Since you had the mag serviced last summer, I'd focus on the wires and plugs. If the wires look worn, replace them. Get wires from your deere dealer, or an antique tractor site like roberts carburator repair. Modern wires will not work.
Unless you are working the tractor hard, you need a hotter plug. D16 would be the correct plug if you are working your B hard like it was 50 years ago. For light work, shows and parades try a set of D21 plugs.
