1020 Diesel starving for fuel update
Frank in WV
09-19-2006 08:01:23
Well mother Deere has found my problems from my earlier posts, seems the injectors were pretty carbon laden and that the fuel injector pump is not delivering enough fuel and needs rebuilt!!!$$$$$ No other choices so one must bite the bullet. My usual luck, worst case and cost scenario.
Ben B.
09-19-2006 20:43:23
 Re: 1020 Diesel starving for fuel update in reply to Frank in WV, 09-19-2006 08:01:23
Before you spend the big bucks if this tractor has a short high pressure type hose between the fuel filters and the pump replace it first. I had a 7520 and a 4020 that would starve for fuel and this hose was it in both cases. the inner linning seperates after years of breaking down from the fuel.
donmyeil
09-19-2006 14:32:41
the pumps and injectors on the two cylinder tractors needed to be run every year or 1200 hours and needed it. the pumps and injectors on the newer tractors should be run every 3000 hours to keep everything at top performance. yeah i know they will run a lot longer than that but you may have one cyl producing a 100 hp and the next two only produceing 50 hp.( hp figures exagerated ,but you get the idea.) guess what is happining to the hot cylinders???? before you condem the mechanics ,go to the pump shop and look at what wears out on these pumps that are supposedely running fine. by the way i'm just a damned old jd mechanic that learned the hard way.customers complaining abt everything when a little maintenance would go a long way.
jdemaris
09-19-2006 11:04:40
And, you believe that hogwash? Carbon on the injectors has nothing to do with anything. And, the pump not pumping enough fuel ?? Well, yeah . . . which can be caused by many things NOT requiring a pump-rebuild.
Frank in WV
09-19-2006 11:40:48
 Re: 1020 Diesel starving for fuel update in reply to jdemaris, 09-19-2006 11:04:40
JD,
I hear whatyou are saying, my problem is not being very familiar with diesels. The replacement of injectors took the miss out of the engine and there is plenty of fuel coming out of the fuel transfer pump according to the mechanic but it is still stalling at wide open from what I understand yielding the rebuild of the pump. Not that it is right or wrong but that pump is 39 years old and could have a problem.
I appreciate your concern and opinion but I am in a position where I have to defer to the mechanic and his deduction of the problem.
Thanks for your help.
jdemaris
09-19-2006 16:20:22
 Re: 1020 Diesel starving for fuel update in reply to Frank in WV, 09-19-2006 11:40:48
I understand completely. I have enough trouble just ordering parts at my Deere dealer - and that's when I've already got the part #s. It sounds to me like your dealer's shop, like many I know these days - are chronic parts replacers, and little more. Of course, there is the counter-argument that with shop-labor of $60, $80, or perhaps more per hour - there's no time for someone to "fool around" trying to repair something. So, the dealer installs new parts - and if they are defective he's covered by warranty. If the new parts are okay - but don't fix the problem - the dealer makes the story fit the situation and the customer winds up buying even more parts. In regard to your injectors - if they were bad enough to make the engine miss, then that certainly would of showed up when they were being checked - it has nothing to do with visible carbon buildup. In reference to your 39 year-old pump? I don't suppose you have knowledge of how many times it has already been apart? I don't believe there is a Roosamaster/Stanadyne DB or JDB pump out there, that old, that's never been apart. Originally it would of had sealed lock-wires on it - and probably the same for any rebuild up to the 80s. Now, most pump-shops use paint on the screw-heads instead of lock-wires for tamper-proofing. I haven't gone back and read your old posts - but I assume you had the common problem of engine shutdown when under power, and it would then restart? If so, it's very likely it IS some failed parts inside the pump. Sad thing is - it IS just a high-pressure oil-pump with some internal controls for delivery timing, volume, engine RPMs, etc. It's not magic - but like anything else - if you don't know how to work on it, and/or don't have service info available, then you certainly need someone to do it. My point is - when I first went to work for a Deere dealer in the 60s, many mechanics knew how to service an injection pump, rebuild a starter, generator, magneto, hydraulic pump, do a good valve job, etc. Now, seems just about nothing complicated is done in the Dealer's shop except change components. So, your injection pump which quite likely can be fixed properly for $50-$60 in parts and five -six hours labor (including removing, fixing, and installing the pump) - will probably now cost $400 - $700 in parts and $200 plus in labor? Most pumps shops use a flat-rate for all pumps - regardless of the repairs needed. So, if a really bad pump comes in - often not worth fixing from an economic standpoint, it is more than made up for with all the other pumps that only need minor work and parts. Not an awful lot different than bringing your tractor to a dealer with a blown head gasket, and he installs an entire new (or rebuilt) engine. And, by the way - I'm not specifically condemning your dealer - I don't know anything about them. My comments are general ones - I'm sure there are exceptions.
Frank in WV
09-19-2006 17:06:13
 Re: 1020 Diesel starving for fuel update in reply to jdemaris, 09-19-2006 16:20:22
JD, thanks for the informative reply. To the best of my knowledge the pump at the most was apart once. I bought it from a family member and to the best of my knowledge over the past 21 years it was in the shop once for an injector to be replaced and engine re timed, thus the pump may have been apart then. The previous owner has since passed away. There is roughly 2200 hours on the tractor. I don't remember if there were wires on the connections or not.
I agree seems a high price to rebuild a pump but from what I understand it is the going rate for rebuilds and heaven forbid you price a new injector pump, it is basically double the cost of a rebuild.
Yes at wide open it would run for a little while then die slow or sometimes quickly, then fire right back up at full throttle.
Appreciate your insight I have dealt with this dealer for a good while just not at this location, so I am hoping all works well.
jdemaris
09-19-2006 20:03:38
 Re: 1020 Diesel starving for fuel update in reply to Frank in WV, 09-19-2006 17:06:13
That pump would probably have a service life of over 30,000 hours if it wasn't for the one piece of plastic in it that deteriorates over time - regardless of hours. If your machine truly only has 2200 hours - there should be very little wear in the pump - just the broken plastic. Seal kit with the new plastic piece is $18. An update can be installed that elimates the plastic for an extra $35. In regard to pricing of "rebuilt" pumps, there are still some shops around that will repair a pump on an individual basis. Cost for a "rebuild" is around $260 plus parts. That's a good deal for someone with a low-hours pump that hardly needs any parts - and it's a bad deal for someone with a worn-out pump that might cost as much to fix as an entire new pump. I put "rebuild" in quotes since I do not believe the word fits the job properly. When a pump is sent to a shop, it's torn down, parts inspected, and parts worn beyond usefullness are replaced. When done, the pump is tested and calibrated on the test-stand, and it will perform as good as new. It is NOT however, AS good as new since it still has many used parts. This is unlike an engine-rebuild where most major wear components are actually replaced and/or clearances reclaimed.
Bob
09-19-2006 08:07:42
What did you expect them to tell you????
That's pretty much SOP at any dealer's shop!
