4020/4010 LP Narrow-front
Fontenot
09-19-2006 07:12:40
I've located a tractor and would like some info if possible. The owner described it as a 4020 or maybe a 4010. It is an LP tractor and has a single wheel, narrow front end. Aside from serial numbers and the like, could anyone tell me if it is indeed a 20 series or a 10 series?
I plan on checking it out this weekend or the following weekend. Thanks.
Mike Aylward
09-19-2006 09:57:49
 Re: 4020/4010 LP Narrow-front in reply to Fontenot, 09-19-2006 07:12:40
Fontenot, if the tractor is a Power Shift it for sure is a 4020. Aside from that and what others have mentioned if it has a Syncro-Range transmission on a 4010 the PTO lever is on the left side of the dash and on a 4020 it is on the right. Another thing to look for is the top dash panel. On a 4010 it is flat and on a 4020 there is a slight overhang on the very top of the dash. There are many other things but these should get you started in case there is no serial number tag. Mike
John179
09-19-2006 09:21:57
Look on the back of the rear end and find the serial number and it might say what it is. Also you could take the serial number call a local dealer and find out. Or look on the shift pattern if has a 7th reverse its a 4010.
gumba
09-20-2006 13:26:53
 Re: 4020/4010 LP Narrow-front in reply to John179, 09-19-2006 09:21:57
My 1966 4020 has the seventh gear reverse-so we can't use that to determine Fontenot's tractor number.
big jt
09-19-2006 08:07:21
If the PTO shaft is held in with a snap ring it is a 4020. If it is held in with 4 bolts it is a 4010.
jt
CLW
09-19-2006 07:51:19
I can't with just that information. I can say that if it has been overhauled the engine would have more than likely been upgraded with the 4020 kit. They stopped offering 4010 kits in about 1985. I have a friend who just parked his 4010LP two years ago after a long good life. He went to change oil and part of a piston and ring came out. He found a 4010 diesel to replace it for less than repairs would cost.
