J.D. 430 Front Loader
Jeff McBride
09-17-2006 21:05:42
Can anyone tell me if a John Deere 430 loader will work on a 1010 Special? Also when you push the clutch in on the 1010 it will keep pulling for 10 to 20 feet. If you let out on the clutch then push it right back in it works fine. I tried adjusting it like the Manual said but it didn't help.
Hayfarmer
09-18-2006 07:10:33
 Re: J.D. 430 Front Loader in reply to Jeff McBride, 09-17-2006 21:05:42
If you are talking about a loader off of a JD430 fitting the 1010, it should. The #35 could be put on a number of models. Might require different mounting brackets but believe they would be similar. The #35 loader would be a good one for the 1010 especially if you want to take it off and on easily.I don't know about the clutch, it may be that the tube the throwout bearing slides on is moving with it. Think it will require a split to determine for sure.
