DLTX10 verse DLTX63
CNESLER
09-17-2006 16:59:30
Is there a publication that describes the differance in model numbers of carburators and which tractors they well fit
Thanks
CNESLER
Glen in TX
09-17-2006 20:46:09
 Re: DLTX10 verse DLTX63 in reply to CNESLER, 09-17-2006 16:59:30
The JD SM2024 Carburetors service manual covers most carburetors used on JD 2 cylinder tractors, engines, combines, balers, beet harvesters, ect. from 2 cyld. era. It's still available from JD publications. It has charts inside with applications and breakdown chart on some parts and what nozzles and economizer plugs fit which carburetors also. It's a good manual to have if you plan on restoring several JDs. The DLTX-10 was used on unstyled Bs as said while the DLTX-63 was the last improved carburetor for the D. You can use a DLTX-63 on any D from 23-53 with good results although it not original for early Ds. A early D will sure run a lot better with a DLTX-63 than the old brass carb if you can't find a good brass carb yet and get you by till then if that's what you are thinking for a D. We put them on early D by tack brazing another brass throttle piece on top and flipping it over which lets the throttle work right then since early D governor works opposite of the later Ds. There was also a 2 page service bulletin that covered JD tractor carb applications and if you want a copy of that email me.
Duane Larson
09-17-2006 18:32:20
Application charts for carburetors used on Deere tractors are readily available, as noted by others. However, it should be noted that while all single barrel carbs will interchange mechanically, some have the butterfly/governor rod holes on opposite sides of the throttle shaft. If you use a carb from an A, G, ... on a D, you will only do it once. As the engine speeds up, the governor on the D acts to close the throttle plate but since the butterfly hole on the A carb is on the opposite side of the throttle shaft from the D carb, it is opening it. So the governor tries harder to close it and opens it further. It takes a very short time to have a D running at more rpms than you ever thought possible.
WeirdDeere
09-17-2006 22:18:04
 Re: DLTX10 verse DLTX63 in reply to Duane Larson, 09-17-2006 18:32:20
We tryed swapping a carb from a 38 D to a 28D. We had to disconnect the plug wires real fast! Never tryed that again!
I've also gotten a nice rebuilt carb on the B, and got the throttle shaft bound up on a cotter pin...wide open of course. Whoa, slow down!
Brandon
Glen in TX
09-18-2006 08:19:10
 Re: DLTX10 verse DLTX63 in reply to WeirdDeere, 09-17-2006 22:18:04
third party image
Brandon, You just have to braze the old carb linkage piece on top of the later D carb linkage to make those work on a early D since yes the throttle governor linkage moves in opposite directions. Many many early Ds here have been found with later D carbs on them and ran well for many more years like that. The DLTX-63 with the gas nozzle installed is a much better carburetor than the older all fuel D carbs. Ran a 63 on a 28 D with .045 high altitude pistons and it would outpull souped up JD As in same weight class.
JD @ Antique Acres
09-17-2006 18:07:26
look here
old
09-17-2006 17:06:58
I can't help much but I can tell you that the DLTX10 is made for the early JD-Bs all fuel type. My 1935 has one of them. Can't help with the other one. I also know the DLTX10 can be a hard to come by carb and when you find one they cost a lot. I payed $500 for the one I have and that was the cheapest one I could find at the time
John T
09-17-2006 17:01:03
Take a look at
www.robertscarb repair.com
John T
