1010 losing charge
TWB
09-16-2006 19:12:52
I have a John Deere 1010 gas that runs fine until you stop it and try to start again.
I have to jump it every time I want it to run. I changed the battery recently and it is already dead (within two starts). If it makes any difference, it has never been kept outside until recently. What is the best way to check the alternator? Or does this sound more like a wiring problem?
Thank you for any help.
TWB
Osage
09-18-2006 05:08:05
 Re: 1010 losing charge in reply to TWB, 09-16-2006 19:12:52
The voltage regulator is rubber mounted upside down under the inner dash framework,(a real bear to get to). As you probably know the 1010's were originally a generator/regulator configuration.
My 1010 had been converted to an Delco 10SI alternator before I bought it. It had problems however with help from Glen & others I resolved the problem.
I had the alternator rebuilt to a one-wire, internal regulator configuration, it works great.
BTW, the idiot light which I changed to a voltage gauge indicated everything was fine when it wasn't.
Osage
Glen in TX
09-17-2006 20:32:37
If it's 12V alternator then check for 12 to 14.5 volts with a voltmeter at battery with it running. Anything under that is not enough and suspect alternator. Has it been changed to a later internal regulated alternator or does it have a external alternator under hood someplace yet? Could be regulator too? If you have some magnetic pull on back of alternator bearing while running it is charging but might not be enough or also bad wiring.
TWB
09-18-2006 08:50:18
 Re: 1010 losing charge in reply to Glen in TX, 09-17-2006 20:32:37
Thank you for the information. It has an AC Delco alternator that sticks out from the side of the engine. I will put a voltmeter on it and see what I get at the battery.
Where would you look to find an internal regulator? You and Osage both mentioned it so thought I would look into it.
Have a great day.
Tim
Glen in TX
09-18-2006 12:01:07
 Re: 1010 losing charge in reply to TWB, 09-18-2006 08:50:18
Take a look at the Mad Electrical site under tech info and you find some help for identifying if you have the later internal regulated Delco 10SI (regulator inside alternator case) or external regulated 10DN alternator. Seems like those 1010 regulators were hid well under the dash? The 10DN is okay when and if it works but you'll be much happier converting it to a simpler 10SI model. At Mad it will also tell you some pros and cons of wiring it one wire or the two wire setup which I like better but just depends on what works for your situation and accessories needed. If you read stuff in other books and sites about putting a screwdriver inside the tab to case on the 10SI to check for charging don't do that as it has to be done quickly and there are other better ways to check charging with meters or bench check testers that won't fry your alternator like that test can. You'll should also find parts catalog for your 1010 at JD Parts.
Link
