70d clutch
stu in njo
09-16-2006 18:38:48
I rebuilt clutch about 1yr ago it has never been right.When I engage it the lever hits the the lite bar then it bounces and pops out. I hold it in with my foot to use tractor. HELP! Thanks for your help. Stu
stu in njo
09-17-2006 08:31:31
 Re: 70d clutch in reply to stu in njo, 09-16-2006 18:38:48
To overhaul it I replaced all bushings & bearings new clutch fork & collar replaced any worn parts.Thanks Stu
F-I-T
09-17-2006 09:06:06
 Re: 70d clutch in reply to stu in njo, 09-17-2006 08:31:31
Stu:
Not sure I remember right, but are you sure that you indexed the fork to the fork shaft correctly? I can't remember if there is only one way to engage the fork with the shaft, or can it fit in any combination of male and female splines? If there is no locator for register, you could have the shaft pointing rearward of where it should be at the engaged position. As I remember, when the lever is locked forward, the shaft bell crank would be pointed 90* from the first reduction cover (basically, parallel to the crankshaft axis). Might be all you have to do is to move the shaft CW one spline. That would explain all of the trouble.
Frank
stu in njo
09-17-2006 13:03:21
 Re: 70d clutch in reply to F-I-T, 09-17-2006 09:06:06
Frank, There is no way to index it it looks like its one spline off. As soon as I can i'll try that and let you know how it works. Thanks Stu
WeirdDeere
09-16-2006 22:10:39
To me, it sounds like you need to adjust your pulley brake. If out of adjustment, I think it would do what you describe. It is pretty simple, and should be in any service manual for the 70. I'll try to desribe it if needed.
Brandon
F-I-T
09-17-2006 06:35:41
 Re: 70d clutch in reply to WeirdDeere, 09-16-2006 22:10:39
Brandon:
You're thinking pulley brake, and I'm thinking from his description that maybe it is just pain loose!
Additionally, maybe after tightening the three clutch bolts with the lever forward, maybe shorten the length of the rod that runs from the fork arm to the rod, which will keep the lever from hitting the lighting standard.
Can you describe what you did to "overhaul" it?
Frank
