Help ASAP 730 Won't shut off
Dan the D man
09-16-2006 09:15:28
we just brought home a 730 diesel pup start and everthing was good untill we went to park it and shut it off. it won't shut off and its running right now as i speak any suggestions on how to shut it off without hurting the tractor???
thanks
F-I-T
09-16-2006 14:31:39
 Re: Help ASAP 730 Won't shut off in reply to Dan the D man, 09-16-2006 09:15:28
third party image
Sounds like a sticking rack or broken rack return spring to me.
By now you know to pull the throttle all the way back while holding the "STOP" button out. This lets the throttle move back farther than its idle position.
On the right hand side of the block is a hex head plug. Under that is a fairly flimsy spring that pushed the rack to idle. Take out the cap, remove the spring. If it is in good shape, not pinched, bent, or broken, the rack might just be sticky. Push a skinny phillips screwdriver or a dowel rod against the button in there where the spring seats to force it to the flywheel side of the tractor. Move the throttle back a run position position, back to idle, push on the rack, and keep repeating until is moves freely. Replace the spring and watch from above (after taking the top cover off) and the rack should return to the left side using the spring pressure alone.
Here's a picture from a 70D book (same set up) that I had handy.
I never had much luck stopping them via choking the air off as they seem to find just enough to leak in to run at an idle. If it is running normally and you cannot stop it, full brakes, ease in the clutch in 6th and she will stop.
Frank
mjbrown
09-16-2006 11:35:13
Pull the decompression lever. That should kill it if it is ajusted right. I don't see how you could have started it if it didn't work .
RalphinWI
09-16-2006 10:39:04
I have a friend that had a 730. It would continue to pickup speed as it ran after starting and didn't want to stop. Turned out that it was burning the motor oil drawn in through a worn valve guide. If you can't shut the fuel off, shut off the air. I was told that some mechanics keep a chunk of 2 x 6 for this purpose on the initial restart after a rebuild, but don't know if it is true.
Scott Griffith
09-17-2006 07:17:51
 Re: Help ASAP 730 Won't shut off in reply to RalphinWI, 09-16-2006 10:39:04
You mentioned burning oil from the intake valve guide. I have a 1950 B that had a crankcase full of gas and after shutting the fuel off it continued to run, picking up speed like a runaway jet engine. I finally had to pull the plug wires to stop it...
Scott
Bob
09-16-2006 09:30:23
I assume you've pulled the stop button, and then pulled the throttle all the way back?
Look at the LH side of the engine, when the throttle rod connects to a lever on the engine. Note which way it moves when a helper pulls the throttle back, and (carefully) manually assist it to move a little more. I used to have a 730 that would need that, after sitting unused for a while. Lube up and free up the throttle linkage from the lever forward, as it is probably dry, rusty, and sticky. There's linkage involved to a foot throttle, too, right?
I hope this helps, and it is not an internal governor/injection pump rack problem!
