# 5 mower cutter bar?
John in CT
09-15-2006 18:04:46
I was just wondering, are new cutter bars 7'( Not knive )still available for a JD #5 mower? Not interested in used. Thanks!
Bruce Giese
09-23-2006 18:46:22
 Re: # 5 mower cutter bar? in reply to John in CT, 09-15-2006 18:04:46
John
using the part number that was listed in a reply, I ran it thru the Depot and they have 2 of them you have to be a dealer to get parts from them, but usually the prices arn't that bad.
mjbrown
09-16-2006 06:26:07
I don't know if you can still buy a new bar but I do know that some were interchangeable. I could and did swap bars between a #5 and a #10. Just gotta check with Deere I guess. I don't know what you have against a used one, they don't wear much. All the wear is on the guards and hold down clips.
55 50
09-16-2006 17:30:41
 Re: # 5 mower cutter bar? in reply to mjbrown, 09-16-2006 06:26:07
The wear will be on the wearing plates, guards and hold down clips ONLY if those parts are changed properly when they get worn. I saw a number 5 on an auction that probably had never had any wearing plates replaced, they were mostly worn completely away and the main bar had been taking a beating of wear for a long time.
John in Ct
09-16-2006 08:48:57
Thanks for replying. Mine got bent once many years ago. We had it streightened in a press and it is pretty good. I am sure that all used ones are at least bent some so I was wondering if a new part was available. Thanks.
Bob
09-16-2006 09:03:58
 Re: # 5 mower cutter bar? in reply to John in Ct, 09-16-2006 08:48:57
My book shows part # Z6439H for the 7' bar.
JDPARTS shows that as in invalid #. It's POSSIBLE dealer would have a newer #, or a subbed part #.
Just to warn you, though, cutterbars that ARE available for newer mowers run $700 to $900.
(YES, that's right, for the simple CUTTERBAR the guards bolt to!)
John T
09-16-2006 05:13:40
John, Ive owned several of them old No. 5's, still have 2 somewhere, and what I liked was you could still buy either Mother Deere or Generic knives n sections n ledger plates n wear plates n pitman arms n hold down clips etc etc at Deere or Tractor Supply or Rural King or Central Tractor. So YESSSSS S you can get a new knife etc most anywhere
John T
pa_popper
09-15-2006 18:21:48
I bought a 7 foot section for my #5 at the local john deere dealer last summer...Worked like a champ.
