Felt axle seals
fredsjdb
09-15-2006 12:23:01
Can the felt axle seals be changed on a 46 B without removing the axles? Thanks for any advice. Fred
RalphinWI
09-15-2006 21:30:31
 Re: Felt axle seals in reply to fredsjdb, 09-15-2006 12:23:01
The usual motivation for replacing these is the gunk dripping from them onto the wheel. Replacing just this (dust seal) will only eliminate oil dripping for a short time. It also invites destruction of the dust seal retainer. The oil seal is at the inboard end of the axle. The "sump" beteen the two bearing also needs to be emptied before reassembly
RalphinWI
09-15-2006 21:30:01
johns48b
09-15-2006 17:58:09
i think your right. i don't believe they were available for my b either. one thing you'll learn quick is don't tear something up unless you have a sure fire replacement in your hands. it may take more than a lot of patience to get those covers off. write back if you need a new set of words. best the wife and kids aren't around for this project. if its pouring oil out, your seal between the power trol and the rear end may be leaking and over filling your rear end. check the level of the oil in the rear end and if its over full then you've found your problem, especially if you occasionaly add oil to the lift. doesn't sound good does it, but you'll be ok.
GeorgeH
09-15-2006 13:46:41
Oops, a lot of what I said is from experience with serial number 201000 and greater. I replaced inner and outer bearings and both kind of seals.
GeorgeH
09-15-2006 13:41:14
For what's it's worth, I believe those felt seals are for dust (outer bearing is grease lube). If like a 50-52, the oil seal is inboard (key 25 page 74 of PC-330). Yes, I also believe the felts can be replaced without pulling axles. The metal covers (called "felt retainer") are hard to get out though and if I remember correctly are no longer available.
