Exhaust leak in 3020
Illinois Farmal
09-14-2006 17:04:57
My gas 3020 has been running poorly and I've thought it was a carb/fuel mixture problem but today I noticed an exhaust leak. Could this be the cause of my motor running rough? As you can tell I'm no engine mechanic and need all the help I can get. Thanks in advance to everyone.
Glen in TX
09-16-2006 07:38:36
 Re: Exhaust leak in 3020 in reply to Illinois Farmall, 09-14-2006 17:04:57
The leak won't help and is not good on valves. What do the spark plugs look like? Black dry sooty then suspect carburetor running rich or restrictions or plugging in air cleaner and air cleaner pipe. Old gunk grease, dirt and mud daubers nest can plug air cleaner so try running it without hose on carb and see what happens. The Marvel Schebler USX carbs seem to have trouble running rich and diaphram blows out in them or other problems crop up later. That is why JD later replaced those with Zenith carburetors. If black oily wet plugs it has too much oil coming past rings with other problems to come or if been sitting a long time may just need ran hard and hot to clean things up and then change oil and plugs again.
