Hayrack Dimensions
Scarecrow
09-14-2006 15:29:46
I have a John Deere 953 running gear that I am restoring and going to make a hay rack into for parades. It currently is set at 10' long and is 6' wide. What is a good dimension to make the floor? I was thinking around 7' by 14'. What was the standard size on these wagons?
randy hall
09-15-2006 16:29:47
 Re: Hayrack Dimensions in reply to Scarecrow, 09-14-2006 15:29:46
the hay racks that i have built are eight by sixteen because this is a good size to bale with. all of the old wagons that i have seen were always seven foot wide and fourteen or sixteen feet long. i always thought that the old hay racks were seven feet wide because a lot of doors were only eight feet wide and the old wagons were the bolster steer type and the wider they were the tippier they would be.
almrm
09-15-2006 12:14:03
I have a similar gear with an 8x16 rack. It is set a little longer I think. It would not be too big for your application. You never know what kind of crowd you will draw with an antique tractor and a hay rack. The Deere gears turn very short so you can get it through a tight spot. The beauty of a hand build 8x16 is that it is the most common lumber and you can build the whole rack without making a saw cut. You get what you pay for. I used 6x6x16 sleepers, 4x4x8 cross members, and 2x6x16 deck planks, all treated. On your gear, this will give you the proper clearence over the tires. My wagon is in JD Photos under 1935 A with a load of straw on it.
Hope this helps.
Mark
Gerald J.
09-15-2006 09:56:11
I had a rack I bought with JD gear with 7 x 14'. I built and bought other racks 8 x 16'. They all worked decently behind the baler though the 7 x 14' rack took an extra layer or two to get up to 100+ bales.
One time I had a couple HS kids stacking and I assigned the smaller rack to the much taller kid. The smaller kid (a 110 pound wrestler it turned out) made a tower 8 high just to prove HE wasn't small.
With 3' x 16" bales, either width takes the width of 5 bales across or one down the middle and two towards the sides and twice that the length. The 7x14 will have a bit more overhang.
So few hay racks are ever bought from a factory, that I don't think there is a codified standard size, just these experiences that 7 x 14 and 8 x 16 and other variations in the same neighborhood worked. Somewhere there were probably some university extension bulletins suggesting workable dimensions.
Gerald J.
billde
09-15-2006 05:39:17
If you are going to use it for hay bales go with 8X16.
Leroy
09-14-2006 16:48:47
Whatever you wanted to make them. Sears (David Bradley) and Wards both sold ready made beds and they had 6'X12' and 7'X14', a lot of homemade beds were 16' with some 18', just depended on what you want. If parades are all you are going to do I would go with 6' X 14', large enough for a bunch of people and small enough to get thru tight places.
mr bob
09-14-2006 16:43:55
inre. to hay rack(hay wagon) dimensions, when we farmed we had a JD running gear wagon with an 8x16 flat bed. we pulled this behind a NH square baler pulled with either an AC D17 or a Massey Ferguson 65. we usually put on 6 layers of bales which gave us around 120 bales per load.
