790 Deere battery Post corrosion
Nylon
09-14-2006 00:01:43
I remember seeing info on 790's with trouble on battery posts. I have a 03 790 with less than 400 hours and the positive terminal is very cruddy. Negative is spotless. Whats the best fix on this? Dont want battery cable to rot off? Otherwise machine is spotless.
Mike M
09-14-2006 11:52:56
 Re: 790 Deere battery Post corrosion in reply to Nylon, 09-14-2006 00:01:43
Does it have one of those strong box (leak box) batteries ? Get a sealed optima battery.
Nylon
09-14-2006 18:25:34
 Re: 790 Deere battery Post corrosion in reply to Mike M, 09-14-2006 11:52:56
Yeah it is a strong box battery. Thanks for the tip on that. And on the block heater.
John
Mike M
09-15-2006 05:54:15
 Re: 790 Deere battery Post corrosion in reply to Nylon, 09-14-2006 18:25:34
I have seen alot of JD's with those JD batteries leaking all over turning them blue.
