Gas in Oil
Woody [NE]
09-13-2006 19:01:47
I have a JD 620 and it has started getting gas in the oil. I looked for old posts and see I should replace the diaphrams in the auto gas shut off. I didn't find much description of this job. I'm no mechanical expert, but thought I could do this. I expect I will need to drain all the gas from the tank. Should I plan to remove the shut off from the tank or can I replace the diaphrams in place? Any gasket seal used? THANKS
Woody [NE]
John VB
09-16-2006 05:12:23
 Re: Gas in Oil in reply to Woody [NE], 09-13-2006 19:01:47
I did this on my 620 a couple of years ago. Not a bad job, but as the other poster said, get your lines and inlets lined up when remounting the sediment bowl unit to the tank. Woody, where are you in Nebraska? I am at Hastings.
Woody [NE]
09-14-2006 16:19:13
Thanks for responses. Wonder if the board was down yesterday. Also received suggestion to change the gasket on the plunger. Wonder if this is listed as 'rubber valve seat washer'??
Woody
Pitalplace
09-14-2006 17:02:59
 Re: Gas in Oil in reply to Woody [NE], 09-14-2006 16:19:13
Yes replace the seat and diaphragms, all rubber parts. The guys at JD gave me all the parts including a new screen for the bowl for less than twenty bucks. Not a bad job, just lay it out as you take it apart so it goes back together the same way. If you have a parts book, it shows how it goes together.
DW
09-14-2006 11:48:28
Yes, you will need to drain the tank and remove the assy. from the tank. Not a big trick to replace the diaphrams, but a word to the wise. Mark the unit so you get it back together with oil and gas lines lining up. Also make sure you don't invert the center section, as it will not work if you do. All I used was a little pipe thread sealer on the threads to the tank. Hope this helps, and good luck. Dale
