730 Diesel Purchase Advice
MattG
09-13-2006 18:23:23
Hi All,
A farmer down the road from me has a 1960 730 Diesel for sale. It is electric start, wfe, 3pth hitch, and the wide fenders with lights on them. It starts right up, doesnt make any noise in the gears, but does have a few farmer fixes on it. The tach shows 3000 hours. The guy bought it 15 years ago and replaced the Flywheel right away as it was cracked.
He also had to fix 5th gear as it didnt work at all. He said he contacted JD and they had 2 ways to fix it. He went with the cheaper way, which caused 4th and 5th gear to reverse on the shifting pattern, but they both work. Is anyone familiar with this?
On the wide front end, the pivit plate has been broken and welded back together. Other wise it is in really good shape. Can you still find replacement parts for the wide fronts?
Other wise it is all there and seems to run and work pretty good. I saw him plowing fields with it earlier this year. He is asking $3800 for it which seems reasonable.
The 3pt lifts well and stays up. He hooked it up to a back blade and put it up and it did not lower for the hour I was looking at it. It doesnt have any oil coming out of the exhaust, I didn't see any oil/water mix in the crank.
Thanks for any advice or what I should look out for.
Matt
Jay in MN
09-15-2006 11:06:19
 Re: 730 Diesel Purchase Advice in reply to MattG, 09-13-2006 18:23:23
buy it if you want 730 Diesel, with the options well worth the price.
Jay
Taswelltroy
09-13-2006 18:51:50
Wish I could find a 730 diesel that cheap!! Where is it located???
billyiron
09-13-2006 18:32:12
you can look all day long and nit-pick it to death,,,its cheap,,buy it ,if you dont like it, someone will gladly take it off your hands,,Id say its worth 5000.00 easy,,BUY BUY BUY,,my 2-cents,,billy
