JD 2840 Hydraulics
Mike in La.
09-13-2006 17:30:58
JD 2840(1978) with front end loader. Hydraulic system works well until the machine warms up, they then become extremely jerky and cease to function. Anyone have any ideas? Where is the pump located on this model and how expensive it to replace? Any help or ideas would be greatly appreciated.
G/MAN
09-14-2006 13:49:36
 Re: JD 2840 Hydraulics in reply to Mike in La., 09-13-2006 17:30:58
You need to get the manual and do the hydraulics diagnosis step by step, or take it to a dealer or independent shop that will. There simply is no hard and fast rule for what the problem "has to be". Many different problems could cause this, and step by step diagnosis is the only sure way to avoid throwing parts at it until it's fixed. I cringe any time I see someone state without question that they know exactly what the problem is, because without diagnostics, you'll never know for sure.
Tx Jim
09-14-2006 12:56:00
Without putting a hyd. flowrater on it's hard to say but the first place I would look is in hyd.oil fill hole for oil spray with engine running. Tx Jim
cannonball
09-14-2006 12:32:06
Just put one in a 1978 2840...parts cost were over 2000..tried to find a used one found one at bootheel.. price was one price when i checked first time, check new price and went back to bootheel price had gone up 250 dollars..no warr either.. was working on it for friend put in new parts... you might have high pressure leak..keeps pump pumping all the time and heating up fluid.. got a 2840 apart now for pto clutch..you have to break it same place for transmission pump..you could have a filter bypass leaking and gets worse when hot.. it allows the fluid to go back into the tractor rear end also allowing the fuild to get hot..could be both..fluid starts out from trans pump to filter, from filter to pto to high low if has one then to front pump.. what front pump does not use goes thur oil cooler back to transmission gears...the front pump goes to steering, then to pressure control valve then to rockshaft, loader and svc ..any which has a bad enought leak can cause what you have.... maybe this can help if not maybe i or someone else can answer anymore questions.... have nice day MAY GOD BLESS THE USA
Steve in PA
09-14-2006 11:45:45
I used to have a 78 2840 that did the same thing the problem is the secondary pump in the rear -end. Tractor will need to be split to fix it. When you take it apart there are 8 steel lines that go together right where it splits so when reassembling you have to make sure they are all lined up before totally pushing it together. The pumps are costly to buy I ended up just selling mine rather than fixing it.
