4020 stuck in the mud; differential lock option?
Tom Anderson
12-13-1999 13:48:40
Guys, I'm in pain when my 4020 duals start spinning on one side in the low ground I farm. Is there a differential lock available for this tractor so all tires always turn; was it factory installed or an aftermarket. How much to install it if an aftermarket. Thanks!
Gerald J.
12-13-1999 21:11:54
 Re: 4020 stuck in the mud; differential lock option? in reply to Tom Anderson, 12-13-1999 13:48:40
I find the differential lock in my 4020 handy to keep it from hopping from right to left wheel and back while disking in plowed ground.
Look for a little pedal at the right front of the driver's seat, on the deck. If its there, you HAVE differential lock. Turn it off by tapping a brake pedal.
Gerald J.
STMTS
12-13-1999 18:24:38
It was factory and is a fair sized job to install in a equipped shop.On all the tractors I added options to, there is a place for it you just have to add parts. The hardest part is adding the clutch disks to the side of the ring gear carrier, the ring gear has to come out.
Phil
12-13-1999 14:15:19
I'm looking to buy a 4020 soon. I don't have much first-hand knowledge about repair but I've read that there was a factory differential lock available. Hopefully I will find one reasonably priced.
Phil
Roger
12-22-1999 21:40:52
 Re: Re: 4020 stuck in the mud; differential lock option? in reply to Phil, 12-13-1999 14:15:19
I have a 4020 for sale that has the differential lock option. Interested?
Red Man
12-13-1999 14:27:16
I've owned 2 4020's and 2 3020's and they all had the factory hydraulically engaged diff. lock.
