48 B clutch dragging a little
Wayne H
09-13-2006 15:13:46
My 48 B clutch seems to drag a little when I first start it up. If I start it in neutral with the clutch pulled back, it seems like I can't stop the flywheel with the brake, although I can hear the engine load up. But if I put it in gear (while sitting on it....) and start it, it seems to free up and then be fine the rest of the day. It's almost like the clutch plates needs lubing where they ride on the shaft???
Thanks
Wayne
F-I-T
09-13-2006 17:44:03
 Re: 48 B clutch dragging a little in reply to Wayne H, 09-13-2006 15:13:46
Might be that the lever stop is misadjusted to the point that the lever is moving too far back. If the lever moves too far back, the operating sleeve and mechanism will move over center and begin to re-engage.
Try moving the lever forward a bit and see if the puley doesn't stop and then start up again the farther you move forward. If so, adjust the stop to get the lever to the centered and at rest position, then adjust the pulley brake to touch at this point, too. This way, coming rearward from engaged, the clutch will pop off of overcenter, and fully disengage as you move the lever back. At the point where it is well disengaged, the brake pad should touch and the pulley will stop.
Frank
Anderson
09-13-2006 17:33:01
You might need to take you clutch apart and clean it. If the tractor was sitting a while, moisture may of got trapped inside the pulley and cause some of the clutch parts to rust.
