JD 50 Water Pump stuck
Dale Crandell
09-13-2006 14:55:32
I have recently inherited a 50 that was stored in old barn for period of time The tractor was running when stored. Water was drained before storage. Now I fine the water pump will not turn by hand. MY question is there a recomended fluid solution I should put in to loosen the pump? I will have other questions I am sure. This is the one I need to resolve at this time.
Thanks for input.
F-I-T
09-13-2006 15:09:34
 Re: JD 50 Water Pump stuck in reply to Dale Crandell, 09-13-2006 14:55:32
Dale:
If the tractor has sat long enough to sieze the water pump, the seal in it is probably shot as well as the bearing. The entire shaft and bearing was not very expensive last time I bought one, and then you'll need the seal, and possibly an impeller if yours has a groove in the seal face area. Resist the urge to flip that impeller over to get a fresh seal face as it is not symmetrical and you risk it rubbing the housing.
If it were me, I'd bite the bullet and rebuild it now, so that you'll only have it off and then re-installed one time. Otherwise, I'll almost bet that if you get it free, it will begin to leak in a few days, and maybe leak a load of expensive coolant on the ground before you catch it.
Frank
