JD 50 Steering Shaft Support
Jack in OH
09-13-2006 05:02:18
The steering shaft support on my 50 is getting pretty worn where the shaft goes through. I saw in the parts manual that there is a bushing listed for this area. Did the bushing come installed in new tractors, cause I don't see one in mine? Or is it for worn shaft holes? Has anyone used one, curious what the O.D. is on the bushing.
Thanks
Jack
TylerARK
09-13-2006 05:37:52
 Re: JD 50 Steering Shaft Support in reply to Jack in OH, 09-13-2006 05:02:18
The bushing is part number B37R, still available from Deere for about $8.50.
The OD is .938
ID is .882
length is 1.75"
They are supposed to have them.
Tyler
F-I-T
09-13-2006 05:32:01
That bushing was installed at the factory, and meant to be replaced as wear occurred. I have one around here somewhere, and when I find it I'll measure it for you. It is not very thick at all, certainly not 1/16th thick as I recall. Yours had one at one time, but it propably wore paper thin and fell out. Now a good thing to do would be to re-bore that hole at the proper angle, and make a custom bronze bushing. It will really tighten up the feel.
Frank
