4020 Hitch Valve
dwag
09-12-2006 16:17:58
Can the hitch control valve be set/adj after a rebuild without using JD8,JD9,JD10&JD11 adj tools? Thanks, John
msb
09-12-2006 21:41:17
 Re: 4020 Hitch Valve in reply to dwag, 09-12-2006 16:17:58
No Way unless you are extremely lucky. That adjustment is the most sensitive adjustment on the whole tractor and the hardest to get correct in my opinion even when using the special tools.
