Blow-by - JD 70
Hooked
09-12-2006 08:09:30
I have a lot a blow-by on my JD70 and the tractor seems to be losing power. Someone suggested that I may need to replace the head gasket. Another suggestion was that the pipe that runs from the governor back to the carburetor might be plugged. Does that pipe send unburnt fuel mixture back to the carburetor to be re-fired and how would that cause blow-by if it were plugged?
Thanks for your ideas.
JDBert
09-12-2006 14:33:31
 Re: Blow-by - JD 70 in reply to Hooked, 09-12-2006 08:09:30
Is the blow by coming out of the tube connected to the valve cover?? Sounds like a ring problem to me- Just Dyno'd mine (new motor) and it smoked like a freight train for about 15 minutes till the rings seated-
NOW if you getting excessive smoke out of the exhaust-
1) what color is it?? Usually a bad head gasket where water is coming in the cylinder will produce white smoke-
2) black smoke is either A- the vane pump (back side of fan where fanshaft and gov. meet) has a leaky gasket OR B- you've got a carb problem.
Hooked
09-13-2006 04:54:30
 Re: Blow-by - JD 70 in reply to JDBert, 09-12-2006 14:33:31
To answer your question - yes the smoke is coming out of the tube connected to the valve cover. I put new rings in about three years ago. I guess they never seated. What would cause that and what do I need to do?
F-I-T
09-13-2006 07:23:01
 Re: Blow-by - JD 70 in reply to Hooked, 09-13-2006 04:54:30
Could have excessive end-gap. Did you measure the bore when you installed the rings? Did you measure the end-gap? Could have standard rings in an over-sized bore. Could have a ring upside down. Did you hone it thoroughly when you installed the rings? Never have had a ring break-in problem as long as I made sure the eng-gap was tight, had tight piston ring lands, and honed the cylinders well for a good cross-hatch pattern.
Frank
JDBert
09-13-2006 06:46:55
Has it done it since you put the new rings in??
IF it has- you need to either get it on a dyno and break it in properly OR take it out and work it. Dont go balls to the walls right away!!! Work it at 1/2 throttle for awhile- then wide open for awhile then 1/2 throttle again ect.
IF it just started doing it I'd say you MIGHT have a broken ring-
