JD 510 backhoe
Ghootjr
09-12-2006 07:41:21
I recently bought a 1973 JD510 backhoe that has a front hyd. pump and a mid hyd pump. It has a PTO lever that is not described in the operator's manual and only briefly described in the technical manual. Everything works fine with it off. I assume it operates the mid hyd pump but I'm not sure. Do you know if it controls the mid pump and when is it supposed to be used? Does the mid hyd pump add more GPM flow for quicker response? Thanks for your help.
