Powr-Trol on 1941 A?
Ron in Mich
09-11-2006 19:35:35
My brothers and I just added our first Green tractor to our collection and know little about them. It's a 1941 A and has a decal on the rear axle that says John Deere hydraulic Powr-Trol. We don't see any type of lift or pump. I've ordered a manual but don't have it yet. Did all the As have hydraulic lift or was it optional? Where is the pump and what does it look like? Also our A has a 6 volt battery and 1 headlight and a generator bracket (generator missing) but no electric start. Is this correct or is the starter missing? Sorry for the dumb questions but I appreciate your time to answer. Thanks!!
j cook (iowa)
09-12-2006 18:40:36
 Re: Powr-Trol on 1941 A? in reply to Ron in Mich, 09-11-2006 19:35:35
If your '41 has a Powrtrol sticker on it, it is because someone repainted the tractor and used "EL CHEAPO" decal sets. The "EL CHEAPO" decals are typically bought at tractor supply and are in fact a "universal" kit, theoreticlly including every possible decal found on any tractor built from 1939 to 1952.
Does your '41 A also have the black ball model designator on it's hood" John Deere didn't put that black ball on a tractor until 1947 but countless "restorations" of early styled tractors sure have them.
How about the air cleaner? Does it have both a "UNITED OIL BATH" (which it is likely equipped with) AND a "DONALDSON OIL BATH AIR CLEANER" sticker (which I am very sure it doesn't have).
Both stickers were included in those kits, so countless numbers of tractors now sport both stickers on the same air cleaner
buckeye al
09-12-2006 10:54:59
Tractors were sold in that era 4 ways electicity wise.
Hand start no lights.
Hand start with battery, generator and lights.
Electric start, battery, generator but no lights.
Electric start, lights, battery and generator.
Tractors of that era had the Power Lift units as options. Power lifts were NOT remote cylinder capable and only operated the rockshaft to raise and lower mounted equipment like cultivators. The power lift was operated by a foot pedal that you could stomp on with either heel. It was either all the way up or all the way down!
The later Power-Trol had a long operating handle pointing up beside the seat instead of the foot pedal operation. It WAS capable of operating either a remote or the rock shaft and could hold either at any position between up and down.
Finally, the power lift and the power-trol had identical footprints and bolt patterns so either would bolt to the basic housing and work just fine. Many of the power lift units on these older tractors have been replaced with the handier and more capable power-trol units.
Hope that helps.
Glen in TX
09-12-2006 09:56:46
It would have pump in the PTO area or a pump mounted on governor drive and a rockshaft lift with the square shafts sticking out sides if you have it or plugs on back to remove for the remote cylinder hoses. Some could come with a lighting and generator package only and still hand crank and saw more of that during WWII era tractors it seems. Check out some info on johnnypopper.com too if you haven't been there.
