1938 JD-A wheels
MT
09-11-2006 18:52:08
Hi guys-just bought a 1938 John Deere unstyled A.It has round spoke rear wheels.They are not cut-offs.It is a 12 spline with 20 round spokes.I can not find F&H any where on wheels.It has a diamond shape hole in the middle of wheel.The hub has number A2894R I think.Any one have a idea what I have?Thanks again.Mike
James Howell
09-12-2006 15:07:53
 Re: 1938 JD-A wheels in reply to MT, 09-11-2006 18:52:08
I recently bought a 1940 B with the same type of wheels. There is a metal tag with JD 1270 R on the rim. These are 38" rims. I was told that they were made by JD.
Duane Larson
09-12-2006 09:46:51
MT,
I suspect you have a set of the replacement F&H wheels with bolt-in hubs. They have 20-7/8" dia spokes and a casting number in the hub of 100625. There may also be (or have been) a metal tag welded between the spokes with JD1270R or JD1271R depending on the rim width (6" or 8"). The bolt-in hub for a 12 spline axle would be A2994R, with a B1961R clamp. I'm not sure what the diamond shape is - this wheel has a triangular shaped hole in the center of the hub where the bolt-in hub attaches. The center of the hub is smooth, with a recess cast in the outside of the center between the spokes.
The JD1270,1R wheels are most commonly found as flat spoke wheels with bolt-in hubs, but they were built by Deere and have the characteristic zig-zag hub casting pattern.
Does this sound like your wheel? What size tires does it have? Are the rims flat across or are they drop-center? These wheels came in several variations and I'd appreciate knowing which version you have.
Anderson
09-11-2006 19:23:39
That is a John Deere part number
