 Jack: Well that does not sound like the original '80' sender that Brandon and I have used. Since yours has the correct resistance, empty and full, all you have to finalize is the correct length for the arm so that is sits on the tank bottom on empty, and just gets to the top stop on the 30 ohms full. Since they have no doubt changed the geometry, you might not be successful. As we had said, the electrical part of those two units are identical, but in order for it to swing properly and give you full coverage of your tank, you may have to adjust the rod so that it is the same length as your original unit. Since the new one pivots mid-way down the unit, my guess is that you had the float off of the bottom of the tank when empty, and the float is now touching the top of the tank when full, before it getsw to the full up position. This would indicate as 3/4. So, you probably need to bend the arm down a bit so that the float rests on or near the bottom on empty and the float uses up the entire range, so that it almost hits the top stop when full. If the arm were exactly in the middle of the unit, the arm would not need a bend. Hold the unit beside the tank and eyeball where the low limt and high limit is. You'll see pretty quick what you need to do to balance the swing, while still achieving "0" on empty and "30" ohms on full up. I've attached a basic sketch that I hope will help you see what I'm trying to say. Frank
