Dyno Chart
Skyhawk Greg
09-11-2006 12:54:59
Would anybody have a dyno chart that they could post, or e-mail, for a stock A, B, or D? I am curious as to what the torque curve looks like. If you only have HP, I can convert. Thank you.
Lynard
09-12-2006 17:57:18
 Re: Dyno Chart in reply to Skyhawk Greg, 09-11-2006 12:54:59
Skyhawk Greg I have the dyno figures for a 38 A I installed .045 stock pistons in years ago. At 975 rpm it had 31 hp and 166.99 ft. lb. 903 rpm 30 hp and 174.5 ft. lb. 813 rpm 28 hp and 180.9 ft. lb. 722 rpm 25 hp and 181.8 ft lb. Have figures for more tractors if you want. Lynn
Skyhawk Greg
09-13-2006 08:59:57
 Re: Dyno Chart in reply to Lynard, 09-12-2006 17:57:18
Lynard, This is exactly the type of information that I am looking for. Going backwards, from 975 RPM, it looks like the torque is steadily increasing. Based upon the slope at 722 RPM, it looks like the maximum torque will happen at about 650 RPM. Do you have any more numbers for lower RPM's? Thank you! Greg
Lynard
09-13-2006 18:09:25
 Re: Dyno Chart in reply to Skyhawk Greg, 09-13-2006 08:59:57
Skyhawk Greg This is as low as you can measure it on the dyno. I have to figure the psi and rpm using the chart and it doesn't read below 400 rpm on the pto. You have to use this conversion to get the true hp. Figuring most John Deeres A and G's they usually have around an 8% torque rise from 975 rpm to 722 rpm. Lynn
Skyhawk Greg
09-14-2006 13:14:41
 Re: Dyno Chart in reply to Lynard, 09-13-2006 18:09:25
Lynn - Yes. Looks like an 8% torque rise as you stated. A friend of mine told me that as the old Deeres run slower, that the torque continues to increase. I didn't ask if he meant literally, or only down to a point. What would be your thoughts on this? Greg
Lynard
09-14-2006 18:21:45
 Re: Dyno Chart in reply to Skyhawk Greg, 09-14-2006 13:14:41
Skyhawk Greg I think the torque will rise but only to a point. It seems by watching the tractors pull on the track the lower comression will pull down to a lower rpm than the higher compression ones. On the B model some of them start going down on torque from 535 rpm to 400 rpm pto. This is probably due to a shorter stroke. Lynn
Anderson
09-11-2006 19:35:44
Take a look at this site. Gives all the Nebraska Testing and specs for John Deere's and Internationals from 1920 to 1970.
Skyhawk Greg
09-12-2006 07:07:44
 Re: Dyno Chart in reply to Anderson, 09-11-2006 19:35:44
Anderson,
The chart that you referenced is a nice collection of data that I will bookmark. Thank you. What I am looking for though, is the continuous printout of torque vs rpm. I am interested in how flat the curve is, and if there are peaks, where they are.
Thanks again,
Greg
Leroy
09-11-2006 14:20:19
I need that chart for all makes for the 30's, 40's. & 50's. Mostly needed for Oliver, Moline IHC, Deere, Massey and AC. Need for local machinery club for pull.
