4010 Standard or special standard production
TD
09-11-2006 09:14:51
Can anyone tell me the difference between a 4010 standard and a 4010 special standard? I noticed in a book I have that there was a special standard produced.
Thanks
j cook (iowa)
09-11-2006 15:55:43
 Re: 4010 Standard or special standard production in reply to TD, 09-11-2006 09:14:51
The John Deere 4010 Special Standard was an export only tractor, produced primarily in 1962 (34 of 35 built were built that year). It has a chassis model code of "6", as in the serial number codes on the serial number plate read like this: 26T35996. Regular standard tractor serial number codes read like : 22T1317.
That number "6" is the all important identifier.
Physiclly, the tractors built as "special standard" were ALL DIESELS, they featured small fenders and a dishpan seat. All other versions were built in higher numbers, only a GASOLINE HIGH CROP would be harder to find. The special standard, once again was EXPORT ONLY.
JD 3010
09-13-2006 11:03:01
 Re: 4010 Standard or special standard production in reply to j cook (iowa), 09-11-2006 15:55:43
I have a JD 3010 with serialnumber 16T30475. Have this one the same history as the 4010? It also has small fenders and a steel seat. My tractor came from South-africa.
sodly
09-11-2006 14:31:17
I"d like to know more about these "odd ball" new generation tractors, too. Do you have any links to pics? I"ve contacted Deere archives about these low volume new generation tractors in the past and they weren"t helpful at all. Seems like unless it"s got 2 cylinders, they won"t talk to you. I"d like to get production numbers for the 3010 and 3020 row crop utility (low profile) models.
j cook (iowa)
09-11-2006 16:07:34
 Re: 4010 Standard or special standard production in reply to sodly, 09-11-2006 14:31:17
I don't have the numbers for the 3020, but the 3010 numbers are:
year gas lpg diesel
1960 3 0 307
1961 405 24 722
1962 120 3 185
1963 125 5 192
total 654 32 1108
The second digit production code for this chassis type is "4", as in a typical serial number of: 14T4762.
