12 VOLT POSITIVE OR NEGATIVE GROUND???
THE JUNKMAN
09-11-2006 08:56:27
For the life of my 1949 JD model A I can't remember if it is a possitive or negative ground. This is a 12 volt system. I have had conflicting answers. Help please
Thanks
Jim
old
09-11-2006 10:19:35
 Re: 12 VOLT POSITIVE OR NEGATIVE GROUND??? in reply to THE JUNKMAN, 09-11-2006 08:56:27
Well it would have been a + ground when new, but and heres the big thing. It would also have been a 6 volt system. If it has a 12 volt genny then it can be either way but if it has an alternator on it and you hook it up + ground you will fry the alternator the moment you hook up a battery to it
F-I-T
09-11-2006 17:19:58
 Re: 12 VOLT POSITIVE OR NEGATIVE GROUND??? in reply to old, 09-11-2006 10:19:35
'49 "A"s were always 12 vdc, positive ground from the factory, two 6 volt batteries in series, but all bets are off if someone has converted it to an alternator, almost all of which require 12 volt negative ground.
Every JD two cylinder left the factory as positive ground.
Frank
DickD
09-11-2006 09:06:28
Your 1949 A came out of the factory with positive ground.
THE JUNKMAN
09-11-2006 09:10:09
 Re: 12 VOLT POSITIVE OR NEGATIVE GROUND??? in reply to DickD, 09-11-2006 09:06:28
I thought it was just like my 52 Studebaker pickup. Thanks for the help
