5410 Diesel won't turn over
ebbsspeed
09-10-2006 15:38:42
Went out to start the tractor and the starter wouldn't turn. Battery is OK, dash lights come on, and there is a relay in the dash that clicks when I turn the key to the start position. The switch under the seat seems to be OK, and I've got the transmission in neutral/park, clutch pedal pushed down, PTO lever out of gear, etc. Any quick ideas on what I should look for? Yhe fact that the relay behind the dash clicks makes me think all of the "safety" switches are OK and working. I can jump the start terminal on the solenoid to the battery and it engages the flywheel and turns the engine over, so I know the starter and solenoid are OK. Any clues? Also, if anyone has a wiring diagram they could email it would help me get this sorted out. Thanks!
johns48b
09-11-2006 10:36:54
 Re: 5410 Diesel won't turn over in reply to ebbsspeed, 09-10-2006 15:38:42
when my other color tractor does that its usually the ignition switch
ebbsspeed
09-12-2006 07:47:49
 Re: 5410 Diesel won't turn over in reply to johns48b, 09-11-2006 10:36:54
The fact that there is a relay clicking when I turn the key to the start position would be a pretty good indicator that the ignition switch is OK, wouldn't it?
