3010 carb or fuel pump trouble
Butch in Sycamo
09-10-2006 08:37:27
My 3010 with an early marvel-schebler carb will only run if I manually pump gas to it from the intake side. The filter sceen in the carb is clean. The fuel pump is pumping gas to the carb, but if it is week maybe there is not enough pressure to get past the float needle to get into the carb.The float needle is also free. Can there be somethig else in the carb that won't let it start? Fuel pump is about $5o so I want to make sure before I buy one. Thanks,
Gerald J.
09-10-2006 20:00:29
 Re: 3010 carb or fuel pump trouble in reply to Butch in Sycamore, 09-10-2006 08:37:27
When my pump failed, I didn't detect why, when hand pumped it seemed to move air. I didn't like the looks or the price of the JD replacement pump, so I made a cover plate with an extension to hold an electric pump. I don't remember which store I bought it from, but it wasn't NAPA. Others had the same pump at a lower price. Worked fine for two years so far. Its really nice to turn on the ignition and hear the electric pump rattle for a couple seconds then slow down as it has built up pressure and filled the carburetor. Makes me think lots of slow starts before were from having to spin the engine with the starter to fill the carburetor.
Gerald J.
msb
09-10-2006 19:53:23
Try pumping the fuel pump while holding a finger over the end of the fuel line to see if the pump is actually building pressure.You can also use a pressure gauge and a hose clamped over the line to see if the pump is building any pressure.It could be the check valve in the fuel pump is bad or I have seen pump lift arms worn so bad that they no longer have enough lift to build pressure.The return spring on the fuel pump lift arm might also be broken or gone.
Gary Moshluk
09-17-2006 19:01:56
 Re: 3010 hard starting in reply to msb, 09-10-2006 19:53:23
My Uncle has a JD (gas) 3010 with a 3020 conversion 'kit' installed. Don't know what a 3020 conversion kit means but the tractor has been parked due to its unreliablility in the field - once it stalls it won't start. It tends to burn up points frequently and runs extremely rich. The carb was rebuilt and a new fuel shutoff solenoid has been installed. Uncle put a fuel pressure regulator in the fuel line (maybe not a good idea). Anyone with similiar experience we'd like to hear from.
Gerald J.
09-10-2006 09:57:51
When the fuel pump on my 4020 failed, the tractor would run with the gas tank more than 1/3 full.
The M-S carb hasn't a great reputation. There's a 1970s vintage JD service bulletin that says if you can't tune it up, replace it with a Zenith. The M-S tune up section of my 4020 shop manual is many pages long.
I suspect the diaphragm under the square cover breaks to upset the fuel mixture and isn't replaced often enough.
It should take virtually no pressure to get gas into the carburetor unless the needle valve is sticking closed or the float is dragging on the side of the float bowl. The needle and float should fall by their own weight.
Float needle and seat do wear badly in 40 years of vibration. They are worth replacing, though in mine (a Zenith) the problem was running too rich.
There's a drain plug in the float bowl you can remove. It should run a fat stream all the time or there's not enough fuel getting to the carburetor.
Simple thing to check, has the fuel shut off been closed at the gas tank. Its not a handy place to get to but its there. Also there's a water drain that might need to be used to get water out of the bottom of the tank. Either will keep the engine from running.
Gerald J.
