4010 Questions
hogman_2002
09-09-2006 22:29:43
How can I remove the snap ring that is on the pto shaft that is behind the rear oil seal quill? I had a bent head pin on one of the shift collars and would like to take the pto shaft out to make sure the bearings are ok. The problem is, I can't get the snap ring off. Can I take the housing off that the rear oil seal quill bolts too, and remove the snap ring from the back side?
Also, what can I do to keep the load bar seals from leaking? I put in a new load bar, along with seals and bushings about 8 months ago, and now the right seal started to leak. I saw on ebay someone was selling load bar bushings that had a groove cut in them for an o-ring. They claimed the o-ring virtually elimated leaking seals. Has anyone tried them or something different that has worked?
Thanks
hogman_2002
09-10-2006 09:41:25
 Re: 4010 Questions in reply to hogman_2002, 09-09-2006 22:29:43
When I replace the loadbar and seals, I also replaced the bushings in the "wishbone". The two on the back and one in the front. I also stuffed as many shims as I could between the wishbone and transmission case. I had it as tight as possible. I currently have the tractor split and would like to fix the load bar seals/bushings along with the pto shaft so I don't have to buy anymore hydraulic/transmission oil. That stuff is expensive from JD.
Mike M
09-11-2006 12:12:57
 Re: 4010 Questions in reply to hogman_2002, 09-10-2006 09:41:25
If you think JD fluid is high priced go buy some Kubota fluid $56.00 and some change or the fan belt I returned that was $27.00 and one for a Deere was $9.00 el cheapo from auto store at only $4.00 is still going around ?
I would for sure use those bushings from Boling Mach. with the o-ring in them I have had real good luck with those.First one I did without had everything new and still leaked so from then on they all got the bushings with the o-rings.
Glen in TX
09-10-2006 08:26:46
Like TxJim said you need to check the wishbone. It has to shimmed and if holes are too worn it will need bushed or replaced. Worn pins and pin holes for lift arms doesn't help either. Replace the front pin and fix hole too. JD has the shim washers in parts catalog. I've used both types of bushings with good luck but none will last if you don't get the slack out of things. Be aware if bushings leak on OD or holes are worn in trans case from too much bushing replacement JD does also make bushings with over size OD. Other worn parts inside can also cause the lift to hop and wear things faster. We finally went back to more drawbar pull equipment for heavy work like chisel plows so didn't have so much replacement of L/D shaft and parts.
Richard 55
09-10-2006 07:47:39
I am in the process of doing the same, I need to remove the pto shaft.You have to split the tractor.Actually I just need to remove the rear hitch support but I have to remove the pto shaft just to get it off.So now i have to split the tractor.
Bob
09-10-2006 06:56:40
Boling machine makes the improved seals.
Doug in IL
09-10-2006 05:57:40
The o-ring bushings work very well. The 2 tractors I've used them in have never leaked again. I have had them in for 8 to 10 years. I got mine from a Deere dealer. I think they had them machined somewhere.
Tx Jim
09-10-2006 03:24:29
To my knowledge the only way to access the pto shift pins on a 3010/4010 is a split between clutch housing and tranns. housing. When you replaced L/D shaft and seals did you shim wishbone to eliminate side to side motion? Stopping side to side motion helps seals last longer. I've heard of bushing with groove but never used any. Tx Jim
