4840 question
Howard H.
09-09-2006 21:15:36
Hi All -
I hope this isn't too "modern" a question, but a friend of mine was plowing with a JD 4840 the other day and it just pulled down and died.
The battery was too low to restart it, so he walked home, took a battery out there the next morning and it fired up and has run fine since (a couple days of work).
Any ideas what could cause such an odd thing?? Can the injector pump air lock?? There was not any obvious fuel contamination in the filters or sediment bowl.
There is not anything electrical that could kill a 4840, is there??
Thanks for any ideas,
Howard H.
G/MAN
09-11-2006 07:46:31
 Re: 4840 question in reply to Howard H., 09-09-2006 21:15:36
It's possible that there's something in the fuel tank floating around that happened to get caught over the fuel outlet fitting. I've seen that happen before. Very unpredictable because it may happen 5 times in one day or not once for 5 days, or it may have to get stuck over the outlet in just the right position to completely block the flow. If that happened, you'd expect it not to start right away as there would be some air in the system, but if the tank was pretty full it's possible it bled itself out some overnight, or bled itself as he was cranking it until the battery died.
Glen in TX
09-10-2006 08:29:53
Thought those still had cable shut off on pump. Could have just hit a hard spot, temporary fuel blockage, or just ran out of fuel in tank and too embarassed to say?
