Bottom plow for JD
Farmer J
09-09-2006 19:51:08
I want to get a bottom plow for my JD 2010 tractor. I think it"s 46-47 hp. What would be the best set up for it. Is that enough hp to pull a 3 bottom plow? and if so what size? 14", 16" etc.
Any help would be greatly appreciated.
Thanks,
Farmer J
Farmer J
09-10-2006 09:20:44
 Re: Bottom plow for JD in reply to Farmer J, 09-09-2006 19:51:08
Thank you all so much for the help. I had found a 3-bottom plow but wasn't sure if the tractor would pull it. I think that is the route I will go. 3-14"
Thanks,
Farmer J.
Leroy
09-10-2006 07:19:48
Stick to 3-14" and ad weight especialy if you have the most popular version, the row crop utility, wide front with 28" rear tires and low to ground
Glen in TX
09-09-2006 21:14:33
third party image
The F110 with stiff standards or F120 with trip type standards were a good match. F35 was made in 3 bottom and there are others too.
Duane Larson
09-09-2006 20:47:41
Farmer J,
We pulled a JD 3-14" pull-type plow all over our farm in Wisconsin with a gas 2010 tricyle, including clay knolls and alfalfa sod. Usually we were in 4th gear in grain, soybean, and corn ground, but dropped to 3rd in some tough cases. I don't recall needing 2nd. The 36" tires were filled with fluid to get traction.
