4010 LP
Richard 55
09-09-2006 15:21:30
Why does the JD 4010 LP use a 6 volt coil on a 12 volt system? My coil just went out and it had a 12 volt coil on it, I have been told that a 6 volt will be hotter.Called the JD parts and they were no help.they did not have a 6 volt in stock and would have to order one.Also i installed a petronics eletronic system in the distributor should I leave the point gap at .015 or would it be better wider. Thanks for any help
Gerald J.
09-09-2006 20:29:59
 Re: 4010 LP in reply to Richard 55, 09-09-2006 15:21:30
There's a ballast resistor part of the ignition switch. It gets shorted by an auxiliary contact on the starter solenoid for better starting.
That ballast resistor can go open, or the wiring to it. My 4020 gasoline did that a few years ago. It would only fire while cranking. So I hot wired it to finish raking hay and then fixed the bad connections at the ignition switch. My 4020 has been rewired to use a ceramic ballast resistor mounted next to the coil.
Gerald J.
Glen in TX
09-09-2006 15:38:21
It has ballast resistor to step down the voltage for 6V coil. Auto supplies should have a coil to work. You can use a coil that is made for 12V but then would need the Pertronix for 12V also and + or - ground. Who did you get the Pertronix from? They didn't have a coil to match it? I suppose you meant gap on spark plugs. I wouldn't open it anymore than .015-.018" on a LPG engine and that's recommended gap for all LPG or natural gas engines. Dry fuel should already be vaporized so larger firing gap is not needed. Larger gap on plugs on LP engines will cause missing and rough running.
