520 compression
frank in PDL
09-09-2006 12:44:18
I have a 520 one side has 100 psi and the other side has 60 psi. How can you tell if it is a burnt valve or bad rings.
Thanks in advance,
frank in PDL
machinery-man
09-10-2006 06:33:13
 Re: 520 compression in reply to frank in PDL, 09-09-2006 12:44:18
Have worked on many of these and I would suspect worn and broken rings. Here is what I would do. Remove rocker arm, will give access to tapping exhaust valve. Apply air as previous posted...start low. If no air coming by valves then it is rings. If there is some air back off pressure tap valve to make it seat and see if it does. You could even remove the spring and rotate the valve slowly with drill to see if see..most of time if valve is okay you will hear a plink seating sound...if more air going past into crankcase....then go ahead and tear down for overhaul...those alloy pistons are good but not as tough as the old cast iron. I would stay with JD pistons rather than after market and would not consider the 3 piece automotive oil ring...stay JD all the way...
ET
09-10-2006 03:25:00
Put a few squits of motor oil in the cylinder. If the compression jumps up a lot you have bad rings, if it stays the same you have a bad valve or a head gasket issue.
Mike M
09-09-2006 16:09:25
Unless you know the history of the tractor if you pull the Head I'd also pull the pistons. Those tractors had aluminum pistons with narrow rings and as the rings wear they break. The old castiron pistons used heavy rings and I have really never saw those worn enough to break,but I have saw several broke in 620's and G's that had aluminum pistons in them.
johns48b
09-09-2006 14:38:07
i don't know that it makes any difference. it sounds like your going to have to tear into it and fix it. you can put a dollar bill over exhaust and see if it is sucked in - burnt valve - right guys? second, put some heavy weight oil in the spark plug hole and recheck psi and if its better i think that indicates ring problems. am i close guys?
jdjack
09-09-2006 14:00:02
I would pull the rocker arm assembly off.
pull the spark plugs out. Apply about 80 psi of air into cylinders and listen at muffler for exhaust valves air intake or intake valves and oil fill cap for rings.
havvey
09-09-2006 18:46:45
 Re: 520 compression in reply to jdjack, 09-09-2006 14:00:02
bingo air leak test it.
