2120 fan belt HELP
T
09-09-2006 11:19:05
Hello
Can you explain that to me a little bit better, I say this because my Dad called me and tells me he has broken a belt, he then tells me he is still trying to get to the point he can put on a new one.
By hearing his voice on the phone it must be difficult, and he has been on it a while. Below is what your response was to the gentleman you responded it to. Can you add to it in a way I can explain it to my dad on the phone for him. Any help would be very much appreciated.
Disconnect pump drive coupler, slide forward, slip belt between damper and coupler and reattach.
Thank you for your time
Tim
Glen in TX
09-09-2006 15:28:04
 Re: 2120 fan belt HELP in reply to T, 09-09-2006 11:19:05
Probably a coupler to hydraulic pump on lower engine pulley and some bolts have to be loosened so coupler can slide off or forward to get belt around lower pulley (damper), around fan & water pump pulley and alternator pulley. Then tighten belt and slide coupler back and tighten coupler bolts.
