2 questions, re JD 2150 and killing moss
StuBC
09-09-2006 07:31:10
There is a JD 2150, looks pretty cool to me. I am growing my farm and would like one do all tractor, that is not too heavy. I am going to be working land and haying about 15 acres. Any advice on a JD 2150. I started out looking for a 2130 but this is what I have found so far. Kind of looks like a large lawn tractor. I will keep my super 55 and 70D.
Moss, we are fighting moss in the meadeaw. We are breaking disk and rototilling it. Plow plugs up in 20' with gobs of it and roots so that stopped. But the moss has a good chance to persist. Any good herbicides for moss? I want to make sure that the moss is dead and would like to follow up with a spray.
johns48b
09-10-2006 15:13:48
 Re: 2 questions, re JD 2150 and killing moss in reply to StuBC, 09-09-2006 07:31:10
sounds ike a good job for a field cultivator first. i've had real good luck killing fence row brush and grass using a profduct called hondo (spelling). its about 70 bucks for 2.5 gals and i've been putting the bottom off of a yard sprayer for fertilizer that my wife used on her flowers full of it in about 10 or 11 gallons of water. it stays dead when you spray it too. a small chisel plow might work to bust the stuff up, but i have a feeling your going to need to drag the mess up in a pile and try to get it where you can burn it up, if the moss is like what we have in n al. a good section harrow pulled behind the chisel plow might help shake the dirt off the roots.
BigMarv1085
09-09-2006 10:11:13
When was the last time this land had lime added to it. Maybe you need to lightly disc it to kill the moss and let the roots dry.
StuBC
09-09-2006 12:39:59
 Re: 2 questions, re JD 2150 and killing moss in reply to BigMarv1085, 09-09-2006 10:11:13
We are starting fresh, this swamp has had no workings ever. The disk that we tried just rode on top, didn touch it. The huge breaking disk takes 20 passes to make it medium chopped. Should we add lime? And if so, at what amount per acre. I am only talking about 6 acres here total.
