410 Backhoe
T A nderson
09-08-2006 21:06:37
Does anybody know a trick to replacing the oring on the rear clutch lube tube not trying to rhyme thats what JD calls it its inside the housing hard to see going back up toward transmission filter the oil filter tube is right above it thanks for any help.
Roy Suomi
09-08-2006 21:21:27
 Re: 410 Backhoe in reply to T A nderson, 09-08-2006 21:06:37
If you're referring to that conglomeration of oil tubes that feed the clutch and brake , They can be a pistol to get seated..The o-rings are seated into a ring groove in the flat plate , then the oil tubes are sealed into these o-rings . I use a silicone grease to lube these o-rings up.And a pair of snap ring pliers to pull the tubes into the o-rings..I bolt the plate in place so I don't loose any other lines in the process.
