1940 AR clutch
Marty Z
09-07-2006 22:03:47
I replaced the dogs, pins, toggles,springs, and disks. Cant seem to get the clutch to work right. When I think it is adjusted right, and take it out for a test , the clutch gets looser. When I tighten it down it won't engage and lock in. What is the next thing that I should replace? My "D" engages great but my AR and GP both act the same with the same replacement parts installed.
Thanks
Marty Z
Mike M
09-08-2006 04:37:14
 Re: 1940 AR clutch in reply to Marty Z, 09-07-2006 22:03:47
Check the pin and the hole it goes in on the operating sleeve. If it doesn't hold it in place it rotates some causing the toggles to tighten or loosen and will give you fits.
Marty Z
09-08-2006 07:40:45
 Re: 1940 AR clutch in reply to Mike M, 09-08-2006 04:37:14
The operating bolts seem to be set in place alright. They don't rotate when I tighten or loosen the castle nuts. It just seems to be a real fine line between too tight and won't snap in, and too loose and won't stay engaged.
Mike M
09-08-2006 09:52:33
 Re: 1940 AR clutch in reply to Marty Z, 09-08-2006 07:40:45
I wasn't talking about the bolts. On the back side of the pulley assy. the operating sleeve ( the part the bronze fork slides into )it also has a oil groove that looks like real coarse threads. It is suspose to be held from rocking by a pin and these get worn over the years letting them move.If yours is moving it can cause that exact same problem you are having.
Marty Z
09-08-2006 09:56:38
 Re: 1940 AR clutch in reply to Mike M, 09-08-2006 09:52:33
OK got it. Thanks . I never checked that. I'm going out to the barn right now. And yes- It has been giving me Fits.
Marty Z
09-07-2006 22:17:49
The clutch sleeve,adjusting disk, drive disk, and operating bolts have not been replaced yet. They all look usable but may be worn. Just not sure what to replace next?
Johan
09-08-2006 03:30:15
 Re: 1940 AR clutch in reply to Marty Z, 09-07-2006 22:17:49
I would check if the clutch fork assembly is operating correctly. Are splines on the shaft worn out? Just my 2 pieces.
