Sediment bowl removal
KJF470
09-06-2006 20:09:05
What is an easy way for sediment bowl removal from the fuel tank? I've tried a pipe wrench on the sediment body but didn't dare try to much force as I didn't want to crack the tank. Any helpful hints would be appreciated! Thanks in advance.
John T
09-07-2006 02:41:30
 Re: Sediment bowl removal in reply to KJF470, 09-06-2006 20:09:05
Its very easy to crack the solder seal into the tank when twisting too hard there..... ... I would soak with PB Blaster or Kroil etc best I could and then get a wrench or what fits on the assembly and use rapping shocking hammer blows NEVER A HARD DEAD PULL on the wrenches end to try n shock n vibrate her loose by tapping in n out in n out.
John T
mitchp
09-06-2006 20:46:03
yeah you sure don't want to pull too hard on it, try spraying a little PB Blaster around it and see if that helps
