I have a 70D and 80D. The Diesel Deeres are great tractors in my opinion, and you can't beat the sound and power. I can't really recommend one model over the other. It really depends on what you want to do with it. Beware that no matter what model you get, it will be pricey to buy/maintain/fix! In case you don't know: The R was the first, a "Standard" or wide front, with manual steering The 80, 820, 830 are all similar with improvments along the way. Standards much like the R, but MUCH improved and more complex. The 70, 720, 730 are rowcrops, all similar, and improved in the later models. Smaller (slightly!) compared to an R-830, but more flexible, more options, more suited to modern work. If you just want to show/parade the tractor, any model will do fine. Pretty much every two cylinder diesel will be big and heavy, requiring a trailer and good sized truck to haul. All the diesels are also good hard workers, but certain models have limitations. The R has a notorius weak PTO drive, and the PTO has to turn to make the hydraulics work, which could be annoying. The R/80/820/830 aren't exactly manuverable either. My widefront 70D isn't much better. A tricycle front 70-730 would turn on a dime. The hydraulics are good on a 70, but get better on a 720/730, with more pressure and more flexibility. The 70-730 have optional three point hitches. The R-830 cannot use a three point. The 70-730 series has some history of flywheel and crankshaft problems. If properly watched and maintained they are fine. But if not there can be expensive problems. The R, 80-830 don't have any issues that I can think of (except the R PTO)...but these were the BIG tractors on the farm, and most farmers made sure to get their money's worth...and you might find plenty of wear on everything. I'll quit rambling on now, hopefully this helped more than confuse. I'll also save the pony vs electric start for later. Brandon
