H John Deere shifting problem
Markkk
09-06-2006 18:43:55
Just got the "H" running and notice the shifting lever is floppy loose and actually slides way down inside the tranny. Very hard to shift and tell what gear you are in. Any idea what the problem and fix is?
F-I-T
09-07-2006 12:20:35
 Re: H John Deere shifting problem in reply to Markkk, 09-06-2006 18:43:55
third party image
Markkk:
There are all of 21 parts in the exploded diagram I'm posting here, only one of which is movable, so I won't be able to provide an explanation that I could describe as "revealing". Possibly informative, perhaps borderline interesting, but I would not choose revealing to describe the problem or the process. I mean, c'mon, it's one moveable part.
The problem, which you probably have already determined, is that the spring tension that holds the gearshift mounted ball in place is gone. Sometimes it's caused by the ball and or socket beging rusted out. Sometimes it's the ball itself, sometimes one or both of the snap-rings have slipped out of the original-cut-pretty-darn-shallow grooves. Sometimes a spring can be broken, or the washers otherwise lost.
Your fix is generally a choice of how to compensate for the loss of "snap" in the snap-ring grooves. I sometimes weld them up, grind down the circumference, then re-cut the grooves. Or, you can install a roll pin through your own drilled hole, or position the assembly in the vice, and spot weld the flat washers in place to hold the spring tension. You can always cut them off later if you need to. I choose repairing back to orignal state, so I rework the shaft to new dimensions. You can also buy pre-welded up and machined shafts. I got one from Sharps one time, along with the necessary parts to rebuild the ball/socket joint. The key is that you some how trap the washer above the spring, and the washer below the spring from moving, and this will keep the ball spring loaded into the socket. Now you might have other wear, like the terminal ball on the very end of the shaft, but it should become apparent after you lift the assembly off the tractor.
A lot of these old tractors have seen a lot of wear in this area, and never received much maintenance, so it's become a popular rebuild activity.
Frank
dan hill
09-10-2006 03:41:18
 Re: H John Deere shifting problem in reply to F-I-T, 09-07-2006 12:20:35
Part # 17 can be worn so much the shift lever can come out in your hand.New snap rings are a must.The leather seal cost 12.00 years ago so you may want to make one.Apron leather works well here.If your H spends time parked outside, cover the shift lever with canvas.The leather will wear and let water in the transmission.
P Browning
09-07-2006 04:55:55
Markkk -- This is becoming a common problem for early styled JDs. One of the two B387R snap rings which stabilize the shifter lever has given way. For a revealing piece on what it is that you are facing, go to the JD-H Restoration Site (below) and one-click (on the left) on TECHNICAL ISSUES. Allow time for the PDF document to come up. You will see an index -- find REBUILDING THE GEARSHIFT, and go to that page in the document and take it from there. (PatB)
Paul from MI
09-06-2006 21:12:07
Probably a worn ball/socket on the gear shift lever. It's an easi fix and most parts are available. Good Luck,
Paul
