Compression ratio
don k
12-12-1999 17:14:44
i am building a jd a and want to figure the compression ratio before i go to far and get it to high does anyone have the formula as to how i do this thanks don k
Chuck
12-12-1999 19:51:38
 Re: compression ratio in reply to don k, 12-12-1999 17:14:44
don't see the worry with the compression ratio, just use JD parts...now if your're building a puller maybe a factor
Gman
12-17-1999 18:26:10
 Re: Re: compression ratio in reply to Chuck, 12-12-1999 19:51:38
Chuck I'd be careful and not get compression too high,I got a '41 G and a '48 G the '41 high compression pistons cam no stroke,the '48 is stock and I can out pull the '41 easy,personally I think the ultra-high compression robs you of the kinetic energy stored in the big heavy flywheel.If you want it to pull put a mild stroke on the crank. Later Gman
