JD 50 801 top link
Jack in OH
09-06-2006 07:04:09
My 50 has the 801 3 point hitch. I was wondering what kind of bracket some of you have come up with to replace the toplink so you can use a modern toplink.
Thanks
Jack
Carl NY
09-07-2006 03:12:42
 Re: JD 50 801 top link in reply to Jack in OH, 09-06-2006 07:04:09
There are some aftermarket hitches that use a bracket that a modern top link can be installed. There is a firm in Ohio that I have purchased just the center bracket to make a 801 a little easier to use.
Jack in OH
09-07-2006 07:46:01
 Re: JD 50 801 top link in reply to Carl NY, 09-07-2006 03:12:42
Carl
Do you have any info on the firm in Ohio with the toplink bracket, I would like to check into it?
Thanks
Jack
Mike M
09-06-2006 07:20:28
What I have found to work best with blades and mowers is to take out the center section, then get a long enough pin/bolt to go through everything when you place the ends of the arms on the outside of the uprights leaving a gap in the middle where you normally hook a normal top link. This seems to get the length about right and it acts as sway control since it is now solider and goes off to each side.
