JD 60 Head on a JD A
Hooked
09-06-2006 05:41:22
I was told recently that a 60 head would fit on an A. Is that any A or does it have to be one of the late A's with head casting #4226?
Thanks in advance for your help.
Drew
09-06-2006 10:14:17
 Re: JD 60 Head on a JD A in reply to Hooked, 09-06-2006 05:41:22
It will fit on ANY styled A that is SN 488000+, not just the late ones w/ the pressed steel frame. The 60 head will bolt in place of the A2325R, A3367R and the A4226R heads.
Hooked
09-07-2006 12:56:02
 Re: JD 60 Head on a JD A in reply to Drew, 09-06-2006 10:14:17
Thanks for your response - will the 60 head also fit on a #2 JD A power block?
Drew
09-07-2006 16:16:45
 Re: JD 60 Head on a JD A in reply to Hooked, 09-07-2006 12:56:02
All the power blocks and the 60 head share the same headbolt pattern. The only issue you may run into is what has been mentioned about some minor frame clearence work.
Island A
09-06-2006 07:31:35
You can use 60 parts on a LATE A to get the dual induction carburetion, that is really the only benefit. You would need the head, valve cover, manifold, carb, and air intake pipes. The exhaust pipe from your A would work with the new manifold I think. A's with 2 barrel carbs are neat.
Dave
Mike M
09-06-2006 07:24:47
I have seen those on the late model A's with the pressed steel frame. The frame needs to be bent up or notched so it fits. I think the A head gasket bolt pattern is the same on earlier tractors too so it may fit on them ? but I just haven't seen one yet.
Glen in TX
09-06-2006 07:23:31
The early 60 has single bore carb and same head as late A. Later 60 has dual induction carb, manifolds and different head. You can put them on late A,AR, AO also but will need dual induction parts also or make modifications. Thought earlier A blocks were different?
