2020 Expert needed
Glen in TX
09-05-2006 21:30:07
Gary still has gear troubles with his 2020. Help him if you can please. Thanks.
WTW
09-06-2006 09:52:28
 Re: 2020 Expert needed in reply to Glen in TX, 09-05-2006 21:30:07
Glen, Tractor for what ever reason is caught in low range mode and when he tries to use high or reverse it is internally bound up as it is in two modes at once. If this is the case 1-4 speeds would drive tractor forward with the other shift lever in neutral. What is unique about this scenario is there supposed to be interlock "shift rail balls" that would prevent him from being able to get tractor in two modes at once. They may have been left out during a previous repair or transmission has some significant wear on it. He did say lever was not going all the way in so that tells me wear is making this situation possible and interlock balls do exist. A broken ear on a shift rail where shift lever contacts it is most likely broke from rail. To replace rail tractor will have to be split and rockshaft assembly removed. Good Luck, Dave W
Glen in TX
09-07-2006 12:22:20
 Re: 2020 Expert needed in reply to WTW, 09-06-2006 09:52:28
Thanks Dave. Maybe that will help him find the problem.
Tx Jim
09-06-2006 03:06:37
If letting out on clutch kills engine it must be stuck in gear.JD utility tractors have been known to break a corner off of tab on end of shift rail leaving them stuck in gear. Tx Jim
Glen in TX
09-07-2006 12:20:50
 Re: 2020 Expert needed in reply to Tx Jim, 09-06-2006 03:06:37
Thanks Jim. Maybe Gary will read it and figure it out. He is in Springtown by DFW area. Are you close to there? I'm way off in west panhandle area. I didn't realize those tractors had a problem with something breaking off inside.
Tx Jim
09-07-2006 12:41:22
 Re: 2020 Expert needed in reply to Glen in TX, 09-07-2006 12:20:50
Glen,I live 30 miles south of Cowtown. Yes,the part that's spot welded or riveted(can't remember)on shifter rail that gearshift handle sticks into have been known to break.Tx Jim
Gary Freeman
09-11-2006 01:24:44
 Re: 2020 Expert needed in reply to Tx Jim, 09-07-2006 12:41:22
Thank you Glen... A few of youmay know Neil Mackie, he came by today and helped me take the top off. There is a trush washer broke in half on the left shifter side in front of the fork. All the gears are ok, were spliting her tomorrow, will let you know what we find. I have been doing a lot of dirt work Neil thanks I may have hurryed it into Rev to much, Thanks again to all. Gary
