4020 and back blade
Nylon
09-05-2006 19:52:21
I have a kind of medium duty 8 foot blade that I am going to weld a cat 2 pin and width set up on so I dont have to flop my sway blocks to hook up to it.
I am wondering how the ld position works on the 4020. will it be light enough of a touch so that I dont bend my blade into a pretzel? I know I won't be setting it in d position and sometimes gravity alone isnt enough to do the job. That lever is a bit tricky and sensitive so thats the resaon I ask.
Also, wondering if any of you guys have put hydro cylinders on one of or both of the drag links. I want to be able to angle pivot the blade since I cant easily reach the linkage levers cause I have a cab. I want to be able to crown my driveway. I can easily reach the 3 point adjustment from on the seat on the Farmall 460 and it works great but it is also makes the job very clean when you can adjust angle on the fly. Any tips on cylinders and dimensions and such would be apreciated. Experience helps in these situation and somebody out there must have some :]
Thanks,
John
Tx Jim
09-06-2006 03:31:39
 Re: 4020 and back blade in reply to Nylon, 09-05-2006 19:52:21
IMHO,the only time you don't need draft control on a 4020 in "D" is when plowing. Mowing and blading need to be in "D" and plowing in "L/D or L". The operator has better control of rockshaft when set in "D" if load control is "adusted correctly". I have a Bush-hog rear blade that has two angle cylinders on it that works nice to crown roads or terrace rebuilds. Tx Jim
Nylon
09-06-2006 10:23:09
 Re: 4020 and back blade in reply to Tx Jim, 09-06-2006 03:31:39
Thx txjim,
I wish I could afford one of those fancy angle blades but they are $3000. :] My dirveway is a 1/2 mile and has some curves and hills. There is some variation in the road so you really have to be constanty adjusting the blade to get it to lay out and crown nice. I was worried that in places where you come over a rise and you have to push the blade down and then go into a dip and try to keep the blade from digging too hard while keeping the proper cut on it would end up putting too much pressure on the blade. A farmall 460 has a float and a locked down position. My first several passes usually are set rigid and sharply angled on the cut side to really heap up the crown. Then I reverse the blade and set it on float and it spreads it out like butter. There are times when trying to do the initial cut when it is set rigid..even when trying to control the fast hitch where I will more or less end up with the wheels off the ground supported by the blade. The fast hitch 8 foot blade is much sturdier than the 8 foot blade on the 4020. Is there any give in the D position on 4020 or is it more or less locked rigid in that position? Since the 4020 is mucho heavier and the blade is lighter I am worried about twisting it.
John
Tx Jim
09-07-2006 03:57:07
 Re: 4020 and back blade in reply to Nylon, 09-06-2006 10:23:09
4020's and all other JD tractors with factory 3pt's have no down pressure in any load control setting. Tx Jim
